TwinTurbo.NET: Nissan 300ZX forum - When I let off the throttle and push the pedal
JMartz
on February 16, 2017 at 4:26 PM
Re: Driveline Slop Question...
posted by nissubaru
on February 16, 2017 at 03:46 PM
again, the shift column moves back and forth. Seems to me that the column is held by the three front drive line mounts. The rear frame contact with the shift column is a slip joint.
JMartz
10:52:44 02/16/17
nissubaru
15:46:12 02/16/17
When I let off the throttle and push the pedal -
JMartz
16:26:57 02/16/17
Re: When I let off the throttle and push the pedal
nissubaru
21:13:07 02/16/17
The differential is mounted to the subframe or
JMartz
06:36:46 02/17/17
Re: The differential is mounted to the subframe or
Smokiedabear
10:21:24 02/17/17
Clunking is generally related to CVs or wear in the
JMartz
12:43:56 02/17/17
